Hi John,
I wish all of those tutorials existed but they don't. All I can point you to are the tutorials I know about that DO exist.
I do actually feel your pain. I came from an AutoCAD background that is drafting based and very different to any kind
of modelling, let alone parametric modelling, which is what fusion is. I learnt the hard way and got critiqued and
pushed quite a lot along the way. I am still learning a lot of things, I am far from perfect but I do have the basics
worked out by simply doing it and reading other posts on the forum.
When I came to the forum, RULE #1 and #2 already existed. After I had put in the hard yards I posted what became
RULE #0 about how to learn fusion. It is the only way to learn it. Pick something you like, practice a lot, recognise
that people like me are trying to help you. Trust me. You are not the first beginner who has gone through this kind
of battering by the forum and you will not be the last. Some of us are a bit blunt with our posts not because we are
nasty people on our high horses but because we are seeing ANOTHER post asking for help that many of the forum
has answered before many times. I still get pipped by some of the Gurus but I just learn and move on. Everyone on
the forum wants to help others using it.
Persistance is the answer. There are some good tutorials in the self paced learning about joints. Joints are not hard
to master but you do have to understand them first.
I must admit I was a little frustrated when I posted this last one because I had spent a long time going through your
file and critiquing it and telling you what needed to be fixed, only on the very next message I see you post you are
talking about what I just told you was the problem. Don't take it personally. I am Autistic and I am a bit blunt
sometimes too.
One thing that I think will help you a lot is to learn about As Built joints. These are where you design a part in the
place it goes and then instead of moving it around you tell fusion it is joined to another component already. What
many people do not realise is that you don't have to put all of your sketches on the three Origin planes. You can
actually put a sketch on the face of a body or component. This allows you to build you first part starting at the Origin
and then start building the next component where it actually goes in the model. In essence you have a portable
origin for each part. Another useful tool is to put an offset plane somewhere for your sketch. Same deal, put the
plane where you want the part to go; project some point from the rest of your model for reference and then start
sketching. Building in place is just one method of designing, the other one used the origin for all parts and you then
use joints to join them together. Some people use one, some the other and some use both. With experience you learn
which one is appropriate. Learn build in place to get the hang of it then move onto the other method and general
joints.
None of these techniques are advanced. They are the next logical step from where you are now, you just have to
learn them. One of the things I have always said to beginners is that time spent doing the tutorials and self paced
learning is NEVER wasted time. There are certainly things I do not know about fusion. I am an engineer only a
couple of years from College. There are some very experienced people on the forum but most started somewhere
and all have gone through some or all of the pain you are currently going through.
Keep practicing things you like to do. Keep asking questions. Keep learning. You will be fine.
Cheers
Andrew
