Registration points on a round internal surface
supinemonkey
supinemonkey
Hi, I'm trying to put simple registration points onto an egg shape and having no luck. As you can see in the image only 4 of the tube shapes will join to the inside of the wall correctly, using the 'to object' distance. The end 2 seem to break the solver. What am I doing wrong here? The error message is characteristically enigmatic:
"Extent boolean fail. The termination entity might not be fully intersected with the tool body built along the operation direction."
Is there a better way to accomplish this? Thank you.
dmorse
Try selecting the back side (outside face) of the egg.
I was able to create the extrude selecting that face.
___________________________________
Dave Morse, Sr. Technical Specialist
APPLIED SOFTWARE | Harnessing the Power to Go Further | 800.899.2784 | LiveLab Learning
etfrench
Use the Extrude|New Component or Extrude|New Body operation and make sure the extrusion extends past the outer shell of the egg. Use Combine|Cut operation with Keep Tools option to split the extrusion in two. Delete or hide the extra body. Join the other to the egg.
ETFrench
supinemonkey
Thank you! Would have loved this to be a single extrude but I had to do it in three.
