Referenced Component Moved after Creating Another Component How to Update New Position in Sketch?
barkster
barkster
I moved a component in assembly that I referenced when creating a new component.  When I enter the sketch of the  new component the referenced component is in it's old position.  How do I update that? I've chosen capture position.
Original Position
Old positionOld position
New PositionNew Position of JarNew Position of Jar
TrippyLighting
@barkster wrote:
... I've chosen capture position.
Not recommended!
Please share your design. Export as .f3d and attach to a post.
barkster
.f3d isn't option for me but here is link and archive.  So I'm not supposed to choose capture position when I move component? I thought if I didn't it would move it back to where it was.  Thanks
https://a360.co/3XlWP6h
TrippyLighting
@barkster wrote:
... So I'm not supposed to choose capture position when I move component? .
No, you are not supposed to move a component so you don't have to use Capture Position.
Ground the Base component to lock it in place.
Us a joint to position the Mason WideMouth where you need it
Start a Cap component and use an as-built joint between it and the MasonWideMouth.
I am guessing the cap is supposed to stay attached to the MasonWM, so when you change the joint position, both will change.
Unfortunately your design does not reveal the design intent, so some f this is guesswork.
Actually, going though the design I don't really know what you need the MasonWM for at all. It's not referenced at all and can be deleted..
barkster
yeah the mason jar was inserted component and I hadn't figured out what I wanted to do with base yet thus my predicament.  so what your saying is I need to delete cap and restart my design? Thanks
barkster
The way to fix it is to edit it's position back in time also.
TrippyLighting
I am not sure that is the case. If you can explain in more detail what your thinking is, then we can move forward from there.
