reduce polygons
reduce polygons
matisok
Message 1 of 8
reduce polygons
matisok
Hi all
I am designing climbing holds in Fusion. I use the "form" tool to made organic shapes. I wanted to try and made more stepped edges in the design instead of smooth. See the attached photo - I get the effect of the yellow on the shape of the grey.
Any ideas on how to achieve that? 
 Mathias
Replies (7)
Message 2 of 8
g-andresen
please share your file
File  > export save as f3d on local device >attach to next post
günther
Message 3 of 8
matisok
File here.
Message 4 of 8
TheCADWhisperer
Save as stl.
Import the stl.
Reduce Face Count.
Message 5 of 8
HughesTooling
You can do it without the export step if you create a mesh feature then convert.
Mark
Mark Hughes
Owner, Hughes Tooling
Message 6 of 8
matisok
Thanks. Both solutions are exactly what I was looking for. 👍
Message 7 of 8
matisok
On the second method - is it possible to convert it back into a solid?
Message 8 of 8
matisok
 I figured that one out myself: turn off design history and then the menu item "convert from mesh to Brep" appears.
