Rectangular Pattern Shortened Menu
gervais5YXPJ
gervais5YXPJ
Does anybody know why sometimes the rectangular pattern menu is a full window, and other times it is abbreviated to one direction? I want to create a pattern along two axes, but sometimes when I pull up the menu and select my sketch curves to pattern, the only window that appears allows for one axis. Why does this happen and how can I make the full menu appear? Often I just cancel and reselect the same exact thing and the menu appears. Why, Fusion?
g-andresen
There is not always a constant behavior.
But the extension of the menu helps.
günther
