Notice: Upload of PDF documents is currently unavailable across the Community due to an ongoing issue.
Rectangular Pattern on Rounded Surface
LiquidTec
Message 1 of 11
LiquidTec
Hello, is there someone who can help me create these types of patterns on a rounded surface? If it were a flat surface, I would know how to do it, but unfortunately, I don’t in this case. Thank you!
Replies (10)
Message 2 of 11
g-andresen
try this
(view in My Videos)
günther
Message 3 of 11
davebYYPCU
If you can't figure in Sheet Metal - an Unfold / Refold setup, then
Use Rectangular pattern for one horizontal row of 9 features.
Presuming it is an Arc and not a Spline - Use Circular Pattern for the curved face (11 rows) Suppress option.
Might help...
Message 4 of 11
LiquidTec
Ohh, that’s an easy one—awesome, thank you! I didn’t know about the orientation → path direction. 😉 I thought I knew how to do that pattern on a flat surface, but now I’ve discovered I don’t 😄
I edited the original post and kept only the Moza Pedal Face example. Do you know how to create a similar pattern to theirs? This is my attempt, but it’s not as good as I would like.
Message 5 of 11
jhackney1972
Your indentations would look a lot better if you used a Loft between your sketch and a Point with a Point Tangent.  The bottom of the shape would come to a clear point.  Model is attached.
John Hackney, Retired
Message 6 of 11
LiquidTec
Thanks, but your model has the same issue as mine. The problem is that there is no centered honeycomb pattern. I can use the Path Pattern only from the middle line polygons because when I select the middle face and one on both sides, due to the curved surface, the extrusion will not be correct. I can’t explain it better, so I’m attaching images—hope they help!
Message 7 of 11
Warmingup1953
Do you want as close as possible to the pedal photo?
Message 8 of 11
davebYYPCU
Unfortunately, you won't get that face from 2d sketches because your dishes have 3d edges.
Combine the oversized rectangular Pattern to the Sheetmetal body.
Can you check the border treatment?
Might help...
Message 9 of 11
LiquidTec
That would be exactly what I wanted, except for the sharp edges.
Message 10 of 11
LiquidTec
Yes, that would be great.
Message 11 of 11
davebYYPCU
Yeah, left that to you to decide.  Outside fillet for the top edges will be easy, and a small inside top edge fillet might work.
Maybe adjust the Shell to align with the dish edge first.  (1.5mm for that if I remember correctly.)
Might help….
