In a sketch, I need to create a rectangular pattern where I need to individually rotate each rectangle based on its center. I created a center rectangle and the rectangular pattern, but the pattern creates what appears to be 2-point rectangles. This means only the source rectangle for the pattern can be rotated from its center.
Is this a "feature" or a "bug"?
Solved by jhackney1972. Go to Solution.
I would think that behavior is as expected...but others may add. Why not add a Point (at the Centre) and pattern both entities?
Follow the sequence outlined in the video.
John Hackney, Retired
I think the other dumb thing I was doing was activating "set pivot", selecting the center, but thinking "set pivot" was a temporary on that'd just set itself once I selected the pivot point.
Watching your demo helped me realize it's a toggle; you need to toggle it off once you pick the pivot point.
Thank you for taking the time out of your day to make that video for me, John!
