Rectangle within Rectangle with a fixed distance to edge
philip2.becker
Observer Observer
philip2.becker
Observer
Observer
I want the lower edge of the inner rectangle 2mm away from the lower edge of the outer rectangle. How do i achieve this?
jhackney1972
When you are editing the sketch, use the dimension tool to select the lower horizontal line of the small rectangle and the lower horizontal line of the large rectangle and enter the desire dimension.
John Hackney, Retired
g-andresen
Left / right?
simple dimensioning
günther
etfrench
You can also use formulas in the dimensions so the inner rectangle will move to the correct position when changing the size of the outer rectangle.
ETFrench
