rectangle with diagonal
simon1199
Message 1 of 10
simon1199
i want to sketch rectangle with lines (like diagonals, see the picture i added)
i did it manually, is there an option to automate the process for example: input information about distance between lines and angel and generate a pattern?
Replies (9)
Message 2 of 10
g-andresen
What do you want to achieve in the end? > picture
Patterns should not be created in sketch mode (although this is possible), but as a feature/body in body mode.
günther
Message 3 of 10
simon1199
Thanks I am new to the software and not familiar with the correct workflow
What I want to create is rectangle that has line stripes of 3mm of depth,T distance between them and angle of D degrees with the x axis. the ability to change the rectangle size, distance between stripes and the degree.
Message 4 of 10
g-andresen
try this
günther
Message 5 of 10
g-andresen
here´s a parametric version.
günther
The occasional warning (yellow) can be ignored because they are caused only when elements are outside the body.
Message 6 of 10
simon1199
thanks very much
if I change the dimension from 300X120 to any other it does not work
any way to fix it? thanks
Message 7 of 10
g-andresen
Of course you have to adjust the base length for the slot.
I did it in the parameter list.
günther
Message 8 of 10
g-andresen
additional parameters:
günther
günther
Message 9 of 10
davebYYPCU
Or just add 2 lines.
Might help.....
Message 10 of 10
g-andresen
Clever!
günther
