Recently opened a file after a month or so of inactivity, and the last save is months older than my last save.
marino.andrew9
Message 1 of 48
marino.andrew9
Originally my file's last save was sometime in early July, but I haven't interacted with the file until today. When I went to re-open the file, the latest save is from March 30th. When viewing my Fusion360 file hub online, I'm given the same data. This is legitimately a career altering loss for a massive project deadline I have, and just everything is completely lost during those months of work. I could understand having a final save corrupted or lost, but I truly do not understand how this much data could just vanish with Fusion. I just attempted an update to Fusion last night but I don't think I proceeded with it, and recently initiated a 30-day free trial of the personal use license. Otherwise my files have not changed whatsoever. Is there any way to recover these saves?
Replies (47)
Message 2 of 48
RajkumarIlanchelian
@marino.andrew9 Do you use multiple machines? If so any change that the file from the other machine did not get uploaded at all? Also if you go into your job status (the clock icon at the top right corner) do you see any pending uploads?
Rajkumar Ilanchelian
Autodesk Fusion
Join Fusion Insider
Message 3 of 48
marino.andrew9
@RajkumarIlanchelian I used to, but as of last year all modeling in fusion has been done on one computer after I switched to a newer macbook.
As for job statuses, I don't see anything present there. It tells me the last version is from March 30, but the project itself shows todays date. Every time I close or restart fusion, a dialog box about "12 paused jobs" appears which Fusion does not provide any more details on. So Im not sure if that is related or not. This appears whether the project was opened or not while using the software.
Message 4 of 48
RajkumarIlanchelian
@marino.andrew9
"12 paused jobs"
This is certainly related. It appears that there are many jobs that has not yet been updated to the cloud. Are you on a Mac or windows?
Autodesk Fusion
Join Fusion Insider
Message 5 of 48
marino.andrew9
MacOS, but I have no way of accessing these paused jobs nor know where they came from. There is also nothing that displays when I click on the clock icon in Fusion.
Message 6 of 48
RajkumarIlanchelian
@marino.andrew9 Can you please do the following:
1. Close Fusion
2. Go to Launchpad - Fusion service utility
3. Run the Gather system info
4. This will generate two zip files
5. Please attach the Fusiondiagnosticslogs.zip to me
Once you have done this
1. Launch Fusion
2. Put it in the offline mode (basically disconnect internet)
3. Now connect it back again
4. Now does the job status have any files that are showing up?
Autodesk Fusion
Join Fusion Insider
Message 7 of 48
marino.andrew9
Currently proceeding with the other part of your recommendation.
In attempting to take Fusion offline, a warning dialog appears telling me that I have some file uploads in progress, asking if I should proceed. Should I do so?
Message 8 of 48
RajkumarIlanchelian
@marino.andrew9 Yes, go ahead. Once you come back online they will start again. The key is I want to see if they appear in the job status again. Also will need the log files as called out too.
Autodesk Fusion
Join Fusion Insider
Message 9 of 48
marino.andrew9
Did you not get the zipped files in my last response?
Attempting to take fusion off online mode crashed the software. I will try it again.
Message 10 of 48
marino.andrew9
Worked on a second attempt to take fusion offline, then back online. But no new job statuses appeared.
Message 11 of 48
RajkumarIlanchelian
@marino.andrew9 I do not have any attachments from the previous comments.
There are certainly changes on the local location that has not reached the cloud yet. The logs are to look into exactly that. In the job state there are four tabs. None of the tabs shows any state right?
Autodesk Fusion
Join Fusion Insider
Message 12 of 48
marino.andrew9
Are you talking about the History, Used in, Used, Drawings four tabs? Only the History tab is relevant to me here, and it only shows the last file being from March 30th.
Message 13 of 48
RajkumarIlanchelian
@marino.andrew9 No. I am talking about the job status in the image attached. Screenshot 2024-08-07 at 1.44.41 PM.png
Autodesk Fusion
Join Fusion Insider
Message 14 of 48
marino.andrew9
Nothing is shown, although I am still told I have 12 jobs paused every time I close the software.
Message 15 of 48
RajkumarIlanchelian
@marino.andrew9 Ok. Can you please try to attach the log files again?
Autodesk Fusion
Join Fusion Insider
Message 16 of 48
marino.andrew9
Here are those files
Message 17 of 48
RajkumarIlanchelian
@marino.andrew9 Received logs. Looking at them now.
Autodesk Fusion
Join Fusion Insider
Message 18 of 48
RajkumarIlanchelian
@marino.andrew9 The logs are certainly showing some errors. I am connecting with our engineering team on this.
Autodesk Fusion
Join Fusion Insider
Message 19 of 48
marino.andrew9
Thanks for that! I'll await hearing back about that. I really hope it ends up being a fixable issue...
Message 20 of 48
RajkumarIlanchelian
@marino.andrew9 Certainly looking at it as a priority. I am trying to see with the logs and files that you provided how we can get the information you are looking for.
Can you give me a point of the file name that you are having this issue with? This will help to isolate it in the log files.
Autodesk Fusion
Join Fusion Insider
