Really struggling with workflow and creating drawings
- Mute
- Permalink
- Report
Hi, I've posted here a few times and so far been given great advice and help, so I'm back again because I'm really having trouble on some of my projects that contain quite a lot of parts, relative to what I've done in the past. I've taken on some work to do design and fabrication drawings for projects at work, and I thought by now I'd have been faster at drawing and at least have been able to improve my workflow. But the problems I'm having is when I'm creating the drawings, I put everything into sub assemblies and try to dimension one specific part, for instance, a single leg with a cap on top, there are 10 caps in different places in the model and 14 legs, creating a drawing for each leg is tedious due to having to turn on or off all of the other components and then try to find the correct cap to show in that drawing. And I need each sheet to contain at least half of the legs to cut down on the amount of sheets we have to print, so that in itself means placing 5 separate base drawings onto the sheet and finding the components in each, it takes so long. Is this the way it should be done or is the reason it takes so long and is so annoying that I'm just doing it wrong?
Thanks in advance
