Fusion Design, Validate & Document
Stuck on a workflow? Have a tricky question about a Fusion (formerly Fusion 360) feature? Share your project, tips and tricks, ask questions, and get advice from the community.
real size of a decal
3 REPLIES 3
jean-michel_legoff
161 Views, 3 Replies
Hello
I am wondering how to manage the real sized of a Decal.
when you import your picture what how Fusion get dimensions?
it's not looking as the real size of the image define in DPI...
So how to do to get a given size?
Many Thanks
3 REPLIES 3
If you need precision, in my experience an image based appearance material is a bit more work, but a better alternative to a decal.
The texture editor allows you to precisely size the image you want to use as a decal.
Yes I know, but as there are no UV unwrap in Fusion, I need to use manage to get the continuity of my texture through multiple faces...
Ahh, yes, that is a limitation!
