Radius on curve
Radius on curve
krunoslav_knezic
Message 1 of 9
Radius on curve
krunoslav_knezic
Hi all,
I was struggling to create some geometry on my latest project, and I would use your help.
I'm trying to create radius that will fallow curve on geometry.
Background
This curve is basically parting line where parts will be split in mold, so I want create radius that will fallow parting line in order to smooth design.
Radius along curve
So far I tried sweep and loft, but without success.
Sweep create geometry, but radius isn't tangent on all geometry.
Loft is giving me trouble, but, also if I manage to create it, geometry is still not tangent on all sections.
Sweep geometry
Loft Geometry
Here is link to part
http://a360.co/1OeCyEz
Replies (8)
Message 2 of 9
innovatenate
Autodesk Support
Autodesk Support
Can you enable the download option on the public link? I wasn't able to download the design, only view.
Have you tried adding G2 to the fillet options?
You may also consider taking advantage of the sculpt environment to get some nice smooth results! Check out this screencast:
http://autode.sk/1Oh85FO
I hope this helps.
Nathan Chandler
Principal Specialist
Message 3 of 9
donsmac
Have you tried the varible fillet command?
Message 4 of 9
krunoslav_knezic
Guys, thank you for your comments and suggestions.
PS I have made model download.
With both solutions I can create smooth tangent radius over geometry.
But what I'm trying to create is that the radius follow split line / plane.
This is important because of injection mold tools.
If radius goes above splitting line, I got undercuts on top part, and vice versa.
Here are additional images to explain.
Split plane with split line, but radius goes above split plane, making undercut for top part in mold.
Message 5 of 9
HughesTooling
Variable fillet gets quite close. If you need it better you could add more points, i've attached the file with my attempt.
Mark
Mark Hughes
Owner, Hughes Tooling
Message 6 of 9
krunoslav_knezic
Thanks for solutions!
I guess I was over thinking with control, that I missed this kind of simple solution.
This is why I love Fusion 🙂
Message 7 of 9
HughesTooling
Looking at the draft analysis it looks like there's still an undercut, I'm not sure you can get what you want if you need tangence with both surfaces.
Mark
Mark Hughes
Message 8 of 9
michallach81
Hi, here's one more attempt with loft. At the and I've picked wrong geometry for draft analysis, but that except that whole vid is ok. I've also attached f3d.
Michał Lach
Designer
co-author
projektowanieproduktow.wordpress.com
Message 9 of 9
krunoslav_knezic
Yes, that's the complete solution I'm looking for.
Was trying also loft, but I was doing it with solid modeling, instead surface.
Thanks for the solution! 🙂
