radius embossed text
dieselguy65
Message 1 of 8
dieselguy65
after wrapping embossed text around  cylinder, is there a way to radius or fillet the top edges?
im drawing up motorcycle handgrips to be 3d printed, and would like the raised letters to have a rounded top surface instead of completely flat with sharp edges.
i have not been able to figure this out.
thanks
Replies (7)
Message 2 of 8
TheCADWhisperer
Create to offset cylindrical surface
or
Split with circle or cylindrical surface.
Message 3 of 8
dieselguy65
i dont think that will get me the desired effect.
i'll give it a try.
Message 4 of 8
TheCADWhisperer
Message 5 of 8
dieselguy65
i'll draw another one up. Ive scrapped every one ive drawn. it really wouldnt be any different than embossed text on a flat surface. i just want all the edges radiused. instead of the sharp corner at the outline.
Message 6 of 8
dieselguy65
http://a360.co/2kzSUS5
hopefully that works.
i'd like to either round the top surface of the text, or radius all the top edges with a fillet or similiar.
not sur ewhich way yet as i havent managed to see how either would look.
the curve of the top surface follows the curve of the cylinder which is a great start.
thanks for looking at this
Message 7 of 8
michallach81
Michał Lach
Designer
co-author
projektowanieproduktow.wordpress.com
Message 8 of 8
dieselguy65
PERFECT! thank you. i hadnt used that rule fillet before. i was trying to select all the edges and do it that way.
