F360 Tutorial: Modifying Sketches 1 Constraints?
I'm wading through the Tutorial, and I cannot resolve the Scissors example.
All okay up to Self check first item - the blades close with distortion of the splines as expected - but I cannot figure out how to stop the spline distortion!
The Tutorial says "add constraints to the spline points similar to:" and then shows drawing that seems to be dimensioned!!?? with constraint symbols exactly as were already present.
Can I ask for a fuller explanation please?
Alan Foster.
Okay, I've solved it myself - it would have been helpful if the tutorial made it clear that dimensions were in themselves constraints.  This is only explained in the Dimensioning Tutorial, which comes later on!
Alan.
