"Rails cannot be tangent to profiles"
oprcmr00
oprcmr00
Is there a way to do this loft?
Thank you.
Drewpan
Thinking it doesn't like the turn at the corner. What if you made a line from that corner turn
straight down to the rail on both sides and did it in two stages? That way you would have a
turn connected to a short pipe.
Cheers
Andrew
davebYYPCU
No.  Not like that.
Rail 3 and 4 will work if similar to 1 and 2 tangent direction, to the vertical edge of the box, but not to the horizontal.
Might help…..
oprcmr00
Ok. Is this ↓ what Drewpan meant with two stages loft?
Update: or this. The model looks good now though... thank you again.
Drewpan
Yes
