"Failed to Boolean bodies together" and not sure where to go from here
I've been working with a model that I imported from an stl (went through the whole conversion from mesh stuff). I realized I needed an internal part to be 4mm higher, and the easiest way I thought of was to copy the model, cut out the outside, and simply move the innards up 4mm and combine the 2 models at the end.
Long story short, I'm trying to combine an imported model with its own part, and I'm getting the message "Failed to Boolean bodies together" I tried google, but it was unclear what my next step should be. I'm happy to clarify further. Thanks!
