Message 1 of 10
The following part will be screwed under a shelf: the A face will be against the wall, the B face against the shelf. I'll use two screws to screw it from the C face but orthogonally to the B face. I would like to use the hole function to countersink my holes but:
- if I point to the B face I cannot "drill" the hole in the right direction with an offset
- if I do it from the C side, the holes won't be orthogonal to the B face
- if I construct an offset plane parallel to B...the hole is blind with the countersink in the middle of my part
What am I missing?
Create a circle the diameter of the screw head on the offset place and extrude-cut towards C? That's not a very simple solution
