I could not import correctly dxfs from fusion to inkscape
fprico
fprico
I am trying to open fusion dxf files in Inkscape. I created some curves and splines. But when I open the dxf exported from fusion in Inkscape the splines appear as segments and faceted. Am I doing something wrong?
etfrench
Inkscape needs to update their spline handling algorithm to be compatible with Fusion 360 splines.  You can try the splines to polyline add-in in the app store, but other people have reported failures
ETFrench
