I wanted to also provide some guidance for setting up a nonlinear material model for the Formlabs resin you provided the reference to. There are two classifications for the Formlabs clear resin: Green and Postcured. Here is the data the manufacturer provides:
Formlabs Clear Resin (Green)
- Young's Modulus = 1.6 GPa
- Tensile Strength = 38 MPa
- Elongation at Failure = 12%
Formlabs Clear Resin (Postcured)
- Young's Modulus = 2.8 GPa
- Tensile Strength = 65 MPa
- Elongation at Failure = 6.2%
In order to create a basic nonlinear material model, we need three additional pieces of data that the manufacturer did not provide: Poisson's ratio, density, and Ultimate Tensile Strength. But we can estimate these properties pretty easily. For Poisson's ratio I suggest searching online for what a typical value of Poisson's ratio is for resin. You can also search the Fusion 360 Material Library for a similar material to find missing data. From my search I think a value of 0.35 is reasonable for Poisson's ratio. I would suggest finding a density in much the same way. Based on my search, I think a number of about 1.2 g/cm^3 is a reasonable number. If you can't find the exact properties for your specific material, it's always a reasonable assumption to average data you find for similar materials. If you are unable to find the Ultimate Tensile Strength, you can use a conservative estimate for this number. The most conservative thing to do would be to use the tensile strength value (which would assume no strain hardening), but I think adding about a 10% increase to the tensile strength is very reasonable. If we fill in the missing data this is what we will use to create a nonlinear model:
- Poisson's Ratio = 0.35
- Density = 1.2 g/cm^3
- Ultimate Tensile Strength = 41.8 MPa
- Ultimate Tensile Strength = 71.5 MPa
To build the nonlinear material model, open the Material Browser in the Simulation workspace by clicking "Manage Physical Materials". The easiest thing to do is find the most similar material from the Fusion 360 Material Library and use it as a base for creating a new material. Enter "resin" in the search box in the top right of the dialog. Let's use the "Acetal Resin, White" as a base for the new material. So go ahead and double click this one to bring up its properties.
If you click the "Physical" tab, you'll notice the material properties are greyed out. You can not edit the materials directly in the Fusion 360 Material Library. Click the button at the bottom that says "Add to Favorites & Edit". Now you can edit the properties and the name for this material which is now in your Favorites folder. On this tab enter Young's modulus, Poisson's ratio, density, yield strength and tensile strength. For the shear modulus, you can calculate this number from Young's modulus (E) and Poisson's Ratio (nu). The shear modulus, G, is equal to E/(2*(1+nu)).
This completes the elastic material properties, but now we need to define the nonlinear stress-strain curve for this material. Click the "Nonlinear" check box in the top right corner of the Physical tab:
A new Nonlinear tab will appear where you can specify the data points for the stress-strain curve. You want to change the type to "Plastic" and use all the default options that populate below. Enter the yield strength for your material in the "Initial Stress Stress" field at the bottom of the dialog. The dialog will automatically populate the stress and strain value in the table corresponding to the point of first yield. For this simple nonlinear stress-strain curve, we'll only add one more data point at the ultimate tensile strength. In the white row of the table, enter the elongation strain and the ultimate tensile strength (in units of kPa). Your nonlinear properties should look like this for the Formlabs Clear Resin (Green). You can also click "Show XY Plot" to see the stress-strain curve as a plot.
Click Apply and the material will update in your Favorites folder. At this point you can right click the material, which is still named "Acetal Resin, White", and click Rename to give it the proper name.
The material is now ready for use, so when you apply materials to your study you can find your new material and put it to use!
Jeremy Wiesner
Research Engineer, Fusion 360 Event Simulation
