Quick Help
Quick Help
Quick Help
Hey everyone. I'm needing some help with moving a few holes closer together. Anyone be able to provide some insight? Thanks so much.
Beyondforce
Hi @Anonymous,
Welcome on board.
Sure we can help, just attach the file or make a screencast and we will help.
Cheers / Ben
Check out my YouTube channel: Fusion 360: Newbies+
Ben Korez
Fusion 360 NewbiesPlus
Fusion 360 Hardware Benchmark
| YouTube
O.Tan
Method 1:
If you're working in timeline, edit back your hole sketch and it'll reposition your hole
Method 2:
Use the move tool, select the holes you want to move and move it to the direction you want
Method 3:
Post your photo here and we'll see how complicated your problem is 😄
Omar Tan
Malaysia
Mac Pro (Late 2013) | 3.7 GHz Quad-Core Intel Xeon E5 | 12GB 1.8 GHz DDR3 ECC | Dual 2GB AMD FirePro D300
MacBook Pro 15" (Late 2016) | 2.6 GHz Quad-Core Intel Core i7 | 16GB 2.1 GHz LPDDR3 | 4GB AMD RadeonPro 460
macOS Sierra, Windows 10
The only thing Im needing to do is push them closer together, without touching, but as close as they can be while still maintaining space between them. Thanks you guys!
Beyondforce
Hi @Anonymous,
Please don't forget R.U.L.E #1, ALWAYS start a new part with a new component!
Here you go:
Cheers / Ben
Ben Korez
| YouTube
Beyondforce
I'm glad it helps 🙂
Ben Korez
| YouTube
