Questions about linear feature patterns
st_smith74
st_smith74
I am trying to complete a linear pattern up to the edge in the attached screenshot. In Solidworks, I can have the number of instances driven by the distance to the edge and the pitch of the instances. This is useful in my model when the length of the carrier tape changes and the number of instances of the sprocket holes changes accordingly. Is this something I can emulate in Fusion360, or is this not a supported feature?Capture.PNG
lucasproko
Hey @st_smith74,
Thanks for your question. You can indeed do this in Fusion by using User Parameters. Once you've specified some parameters for length, spacing, etc, you'll be able to use expressions to calculate the number of instances that you'll want in your Rectangular Pattern. I'll include a few more detailed documents below to help you learn the workflow.
Here's a detailed article that walks you through the Change Parameters dialog box:
https://help.autodesk.com/view/fusion360/ENU/?guid=GUID-76272551-3275-46C4-AE4D-10D58B408C20
More specifically to your situation, here's a quick gif I made to show you how you can accomplish what you're going for:
And here's the file I used to create that: https://a360.co/2KaLgdI
You'll be able to get even better results by using some of the rounding functions found in the first article like floor() and ceil() when you're calculating the number of instances for the pattern. Let me know if you have any additional questions!
Lucas Prokopiak
Fusion 360 Product Manager (Sketch/Model)
