Fusion Design, Validate & Document
Stuck on a workflow? Have a tricky question about a Fusion (formerly Fusion 360) feature? Share your project, tips and tricks, ask questions, and get advice from the community.
Question on appearrance
12 REPLIES 12
Message 1 of 13
gillesht
608 Views, 12 Replies
gillesht
I've applied Nylon 6-6 (White) to my model. Why am I getting all those lines on my model? Please look at the attached file.
Best regards.
Best regards.
12 REPLIES 12
Message 2 of 13
keqingsong
in reply to: gillesht
keqingsong
Can you post a couple more screenshots here so we can examine your model? Attach the pics directly (don't put in a Word doc). Also, what are your system specs and graphics card specs? And do you have any visual effects on?
Keqing Song
Autodesk Fusion Community Manager
Portland, Oregon, USA
Become an Autodesk Fusion Insider
Keqing Song
Message 3 of 13
gillesht
in reply to: keqingsong
gillesht
I have an Intel(R) HD Graphics card in a Dell Studio 1749 laptop. No visual effects on. I've posted a picure of my model that shows lines on the surface.
Best regards.
Best regards.
Message 4 of 13
gillesht
gillesht
I've posted another picture ans it seems that those lines are coming from a reflection of a light source. How can i get rid of that?
Best regards.
Best regards.
Message 5 of 13
keqingsong
keqingsong
So I dug into this and found the your crash error report you submitted today. The issue you are seeing is most likely caused by your graphics driver being out-of-date. You should update it here https://downloadcenter.intel.com/search?keyword=2nd+Generation+Intel%C2%AE+Core%E2%84%A2+Processors+...
Or get the utility here http://www.intel.com/p/en_US/support/detect and have it auto-detect what update you need.
Let me know if this solves your issue.
Keqing Song
Keqing Song
Message 6 of 13
gillesht
gillesht
I got page unavailable when I tried to get the utility. I've discussed with Dell support and there saying the I have the lates driver available for my laptop. What's next?
Best regards.
Best regards.
Message 7 of 13
innovatenate
innovatenate
Autodesk Support
Autodesk Support
Can you go to the Help (?) menu and run the Graphics diagnostics command?
In the following dialog, there is a command to "Copy to Clipboard."
Can you paste the contents into a reply here for further analysis?
Nathan Chandler
Principal Specialist
Nathan Chandler
Message 8 of 13
gillesht
in reply to: innovatenate
gillesht
I click on Copy to Clipboard and nothing happens. Any idea why?
Best regards.
Best regards.
Message 9 of 13
innovatenate
innovatenate
Autodesk Support
Autodesk Support
The button should place some contents on your clipboard. There's no graphical indication that anything happened. However, whenever you use the paste command (CTRL + V), the contents should paste into wherever you are typing (like in a reply to this forum).
Let me know if you have any questions.
Nathan Chandler
Nathan Chandler
Message 10 of 13
gillesht
gillesht
[GPU Information]
GPU Device: Intel(R) HD Graphics
GPU RAM: 128 MB (Integrated card)
GPU Driver API: DirectX 11.0
GPU Driver Verison: 8.15.10.2104
GPU Driver Date: 03/31/2010
[Graphics Effects Settings]
Anti Aliasing: Off
Ambient Occlusion: Off
Object Shadow: Off
Ground Shadow: Off
Ground Reflection: Off
Selection Display Style: Simple
Transparency Effect: Better Performance
[Notes]
1. If you have another discrete GPU on your system it is recommended to run Fusion on it to get better performance.
2. The graphics card driver version is old and could be out of date; please check with your GPU vendors to download and install the latest one.
3. If your graphics card is old and doesn't support DirectX 11 well, you may switch to use DirectX 9 through the Graphics Driver option in Fusion 360 preference dialog.
4. The effects could slow down the graphics rendering; try to limit them for optimum performance.
[Limit all effects to provide optimum performance]
On
[GPU Information]
Anti Aliasing: Off
Object Shadow: Off
Ground Shadow: Off
[Notes]
On
Message 11 of 13
innovatenate
innovatenate
Autodesk Support
Autodesk Support
A couple of interesting things I note from the graphics diagnostic results. The first thing that stands out is that the date is from March of 2010. A general rule I usually offer is to update the graphics driver every six months or so. It seems that the currently installed version was release over 5 years ago. You may want to look for a video driver directly from the Intel website to see if there is a newer version available to test. See Keqing's earlier links for the Intel website.
Another thing that stands out is that the Intel Card is an integrated (with the motherboard) with 128 MB of dedicated video memory. The system requirements recommend 512 MB of dedictated video memory. Does this system have dual graphics cards? Perhaps the discrete graphics card is not being utilitzed?
Feel free to send me a copy of the system information file:
1. Launch %windir%\system32\msinfo32.exe
2. Select Save from the File drop down menu (CTRL + S)
3. Please reply with the resulting *.NFO file attached or e-mail it to me directly at nathan.chandler@autodesk.com.
Please note if there are dual graphics cards, there are some specific suggestions that may help in the below link.
http://knowledge.autodesk.com/support/fusion-360/troubleshooting/caas/sfdcarticles/sfdcarticles/On-l...
Let me know if you have any questions. I hope this information is helpful.
Nathan Chandler
Nathan Chandler
Message 12 of 13
gillesht
gillesht
The graphics card driver was custom built for Dell for the Studio 1749 laptop. No update available. as for the memory size there no parameters for the laptop to increase the memory allowed to the graphics card. So I have to live with the constraints.
Best regards.
Best regards.
Message 13 of 13
gillesht
gillesht
The public link is http://a360.co/1gdaN6y
As for the Intel driver update utility I've attached a picture showing the results.
As for the generic driver I've tried to install one and got the message that my laptop was not meeting minimum requirements.
Best regard.
Best regard.
