question about self-intersecting surfaces when converting t-spline body
itchytoes
itchytoes
Hi --
When I convert my t-spline body, I get the error notice about "highlighted surfaces may be self-intersecting.  Try modifying...".
I have two questions  (1)  How do I see the highlighted surfaces because I don't see anything that looks highlighted.  and (2)
What is the best way to unweld adjacent edges?   -- I couldn't find an item for that on the various menu dropdowns.
Betty
itchytoes
Hi --
Oh wait -- I just found the Modify --> unweld edges command, so I don't need (2) answered 🙂
jeff_strater
You should be able to just click on the error message in the dialog, and any self-intersecting faces should show in red:
To untangle the intersections, I find that using Box Mode (in the Utilities -> Display Mode command).  I find it easier to be able to see problems with the surface in this mode, and it's easier to move the edges or vertices apart.
Jeff
Jeff Strater
Engineering Director
itchytoes
Hi --
n
Thanks for the suggestions.   I was able to find the red highlighted area in one case and I fixed it by welding two vertices.  However, I still got an error, and then I just could NOT see the red mark anywhere.   I tried zooming in as well as I could and I just couldn't find it.  The body I was working with had many edges and faces.    I don't suppose there's some easy trick to finding where the errors are.
Betty
jeff_strater
Sometimes the self-intersections are very small, and hard to find.  The only trick I sometimes use is to switch to Box Mode in the Display Mode command under the Utilities menu - you can sometimes see the intersections better in this mode, just by seeing where the edges overlap.
If you want to share the file, I'd be happy to take a look at it (though probably not until tomorrow...)
Jeff
Jeff Strater
