Pyramid type shape ?
I seem to not be able to create a Pyramid type of shape. The shape I'm trying to make is a "Hip" roof, not the construction just a basic block shape. Any suggestions ?
HughesTooling
Draw a rectangle and extrude tapered, the taper option doesn't show until you start to extrude.
Mark
Mark Hughes
Owner, Hughes Tooling
Awesome, thank u.
JDMather
See attached.
I_Forge_KC
If you want different tapers on the two sides, try something like this...
Note: There are better/faster ways to constrain your geometry if you want the mid-point snap like I did there, and the extrude cut is better done with through-all instead of a distance.
K. Cornett
Generative Design Consultant / Trainer
Thanks again.
I_Forge_KC, I thought of doing it like that to begin with and shall keep it in mind, I'm still curious what exactly can be done in F3D.
HughesTooling
Here's another way using draft, you could use more than one draft feature if you needed different angles on some sides.
Mark
Mark Hughes
