Putting a constraint between two objects
Hi, I'm Gael.
I'm a student and I work on Solidwork in my school but with a MacBook at home I can't use it so I just begin on Fusion 360.
I'm sorry if this question has been already asked, but is it possible tu put constraints between two objects (distance, coincidences...) like Solidworks, so the two object automatically move to put them together at the right place and lock it ?
Thanks for your answers 🙂
Gael
PS : Sorry for my English I'm French
TrippyLighting
Yes, No.
1. Yes, you can assemble your components (the MUST be components, not just bodies) using the joints.
2. Fusion 360 joints work dfferently than solid works. They are not just mates or geometric constraints.
I'd suggest you watch some of the intro vdeos for Fusion 360. There are also some other SolidWorks specifics.
Create and activate a component first before you start sketching.
Don't start highlighting stuff in the Browser and use the move command. It's not doing what you think 😉
HughesTooling
You need to look at joints in Fusion, here's the Help.
Mark
Mark Hughes
Owner, Hughes Tooling
Great ! Thank you very much for your help 🙂
O.Tan
And for a heads up, there's no Part of Assembly in Fusion, it's all called Components.
A single component is similar to a Part
A group of components is similar to a Assembly
The icon will be different.
Feel free to ask more questions!
Omar Tan
Malaysia
Mac Pro (Late 2013) | 3.7 GHz Quad-Core Intel Xeon E5 | 12GB 1.8 GHz DDR3 ECC | Dual 2GB AMD FirePro D300
MacBook Pro 15" (Late 2016) | 2.6 GHz Quad-Core Intel Core i7 | 16GB 2.1 GHz LPDDR3 | 4GB AMD RadeonPro 460
macOS Sierra, Windows 10
HughesTooling
To follow on from Omar, take a look at this thread and the bit about using and activating components. Fusion-360-modeling-best-practices
Mark
Edit I meant this thread although the other one's worth a read.quick-tip-why-you-should-activate-a-component
Mark Hughes
patrick.emin
Bonjour, pour votre information, nous avons un forum en français  à Fusion 360 - Français - Autodesk Community
Patrick Emin animateur de la communauté francophone
Vous avez trouvé un message utile? Alors donnez un "J'aime" à ce message!
Votre question a eu une réponse satisfaisante? Voulez vous avoir l'amabilité de cliquer sur le bouton
 APPROUVER LA SOLUTION  en bas de la réponse qui apporte une solution?
Signez notre Livre d'Or
