Puting form into new design file
I am New in Fusion 360
i have a question. I am working on a car model.
i have three different forms,now how can i share my first form to a new design file?
or i have to share the body?
is it possible?
if yes, how?
Thank you in advance.
innovatenate
Autodesk Support
Autodesk Support
If you're in a parametric timeline environment, you can copy and paste from and to an active sculpt environment between designs. You have to be in the "Create Form" environment in both workspace for this to occur.
Hint: You'll see Finish Form in the ribbon when you're in an active sculpt environment.
I note that you can also copy BREP bodies and surfaces into a "Base Feature" environment.
Copying and pasting bodies gets a little easier when you are working in a Direct Modeling environment
I hope that helps! Let me know if you have any questions.
Nathan Chandler
Principal Specialist
