Re-anchor doesn't seem to work too well with push pull. I've recorded a screencast to demonstrate, the first problem is after selecting the face to Re-anchor to the offset doesn't update until you start to drag.
The second problem is if you try to enter a size in the input box the Re-anchor is ignored and the original anchor point is used. In this image you can see the offset from the new anchor point shows 30mm but the input shows 10mm. Surely the 2 sizes should match.
Mark.
Mark Hughes
Owner, Hughes Tooling
