Push pull - plane gets in teh way
derricksalmon
derricksalmon
Hi
I am doing lesson 2 on getting started where we array 6 small circles on the bottom face of an extruded cylinder.
When I try to push/pull these circles, push pull selects a suface defined by the top inner edge of the cylinder, so I can't get at the circles below.  I tried deleting this 'pseudo' surface - but to no avail.
How do I disable or otherwise get past this top surface
cheers
D.
Oceanconcepts
In Fusion, if you press and hold down the left mouse button when selecting, you will be presented with a menu of items that are selectable. This allows you to select something that is behind another object, or specify when selection is ambiguous, as when multiple objects occupy nearly the same space.
- Ron
Mostly Mac- currently M1 MacBook Pro
