Push Pull gives wrong Result
6 REPLIES 6
docara
582 Views, 6 Replies
Hi
I have a problem with the Push Pull comman.
I have created a design which I want to reduce the overall width of a body by 1mm total. Now I hit Q choose a face and move as per normal I enter a value (-0.5). I now measure across the faces expecting to see 16.5mm but I get 16.8mm. If I enter -1 the result is 16.3mm
I have included just the exported body - please ignore the yellow boxes they're not evident in the 'proper' original design but the behaviour is identical in both.
Any ideas
6 REPLIES 6
laughingcreek
in reply to: docara
you didn't indicate which face, and nothing seems to match the value you gave, so it's hard to know where your talking about in your file-
but
I suspect it has something to do with this setting in press pull-
Ideally you would set this model up in a way that all these values can be changed and adjusted by changing a dimension in a sketch, and not by adding more features to the timeline.  you appear to be basically using DM modeling techniques in a model with the time line on.  that's fine, but does tend to get messy over time and can cause weird user imposed errors to creep into a design.
docara
in reply to: laughingcreek
Hi laughingCreek
As mentioned I just pulled this out of my working drawing and its something quick and dirty.
Here is a side view and dimension
I want this to be 16mm so I tried to Push Pull -0.5mm on each of these faces.
docara
in reply to: docara
Update
Interestingly the Update face does achieve what I want but why didn't PushPull?
laughingcreek
in reply to: docara
press pull behaves the way your expecting if you change the type from "automatic" to "new offset".  right now it's trying to modify a previous feature (which is why it's starting with -.3mm as the value).  if you don't change it to "new offset", it will change it relative to a point that is .3mm away from where it currently is.
docara
Ah! Thank you I understand now.
Eating a some humble pie again concerning your first comment. If I created the component properly I wouldn't have come across this.
TrippyLighting
in reply to: docara
Yea, but you would not have learned this eitern 😉
