Properties > Physical > Bounding Box > Visible Only
tedbradley314
tedbradley314
Hi, I create products that are assemblies of multiple subcomponents. I need to be able to determine the bounding box dimensions of sub-assemblies. It seems the "Properties > Physical > Bounding Box" feature takes into account all of the bodies and child components regardless of whether or not they're visible. For me, this means a 10minute process of running through all of the sub-components, breaking links, deleting all hidden bodies, etc. Is there a better way to get the bounding box of visible bodies and components only?
When you create a drawing from a design, there's a dropdown to select "Visible Only". It would be great if physical properties bounding box had the same option.
Rushikesh.kadam
@tedbradley314 Apologies there was no reply for this post for a long time.
Thank you for proving valuable feedback. This option is a good value addition to the Properties dialog. I have created an enhancement request and assigned it to the concerned team. Once again, appreciate your effort in developing the software.
If my reply was helpful, please click the "Accept as Solution" button. This helps others get the answer more quickly! "Like" is always welcomed.
Rushikesh Kadam
Senior QA Engineer
Quality Assurance
Autodesk, Inc.
