File Origin is basic location for inbuilt functions like symmetry, and stability.
Your file is constrained, but away from the origin is extra work,
Gunther has the hexagon and circles positioned on the origin, for stability, and bonus of aesthetics, in the static thumbnail. Much easier.
This example does not need any separate components. File starts as an empty component,
make the simple part at the top, and you won’t have to combine across components. What Rule No.1 talks about. Multiple (finished) parts multiple components, multiple steps to make a single part - Go in the same component.
Yep lots to learn, take small steps at a time.
Difficulty with constraints - need examples to explain, but deleting them let’s you edit better.
your pic was not present when I started this reply, so Editing now.
Lets see you create 2 user parameters, Create 2 lines, and use 2 dimensions on those lines,
to replace a single origin point that Fusion supplies, and you HAD to use for your construction to actually work. Hard work that is weird workaround for a non existent problem.
For me, Draw four dimensioned circles at the origin, will do the same job and be more simple in the process. If - big IF, you don’t want the circles at the origin, you don’t put them there in the first place, again counter productive trying to move them away. Use the user parameters to place the 1st centre point, don’t need the centre lines - at this stage.
Might help...
