Projections Not Updating with Change in Circular Feature
tranq006
tranq006
Hello All,
In the video, I show some male extrusions that fit into notches created with a circular feature. The male extrusions are offsets of projections of those notches. When the notches are changed (by changing the angle shown in the video), the projections do not update and change. Why is this?
On a side note, I find projections in Fusion to be far less stable than other softwares such as Solidworks
davebYYPCU
Projections work for me, there are known issues with arc / circles and parameter changing.
No file the question has no answer.
Might help....
TrippyLighting
I agree with @davebYYPCU that this is hard to assess without the design file on hand.
tranq006
Unfortunately I cannot share the file on this one
davebYYPCU
Recreate a replica dummy file that does the same thing.
Sometimes doing so fixes the workflow, and you solve it yourself.
Seems to me, that your socket sketch edit has no relationship to the blocks, and there should be.
Might help….
tranq006
The blocks are projections of the sockets, not the other way around as you stated. In the video you can see the projections.
I can try to recreate it
