Projection symbol
Projection symbol
Projection symbol
How can i add the projection symbol to my drawing?
I see a big space on the drawing title block, where i would like to add the first angle projection symbol (or the third angle projection) but I can't 😞
Cheers
Bernardo
lnonnato
Hello Bernardo,
It's not only the projection symbol you cannot insert in the title block ! Also company logo, changing the title block layout ...
These options are long overdue. Let's hope Fusion team takes care of them in the near future ...
Luiz
TimeraAutodesk
Hi @Anonymous, thanks for your inquiry. @lnonnato is correct that we currently don't have the ability to create custom title blocks (or insert images into existing title blocks). The team is actively working on improving and extending the title block capabilities, and you can expect to start seeing us deliver more functionality in the next few releases.
Thanks for your patience, and let us know if we can be of any additional help in the meantime.
Best,
Timera
Thanks for the answer. We will have to be patient, then.
Bernardo
TimeraAutodesk
Hi All,
I just wanted to follow up with everyone on this thread to make sure you're aware that we added a new feature in the July 22nd update of Fusion 360 that allows you to insert an image/Logo into a title block. We are continuing to work on enhancing the title block experience, and you can expect to be able to upload your own dwg title block for use in Drawings in an update soon as well - but I hope that the ability to add in a logo is also helpful in the meantime.
For more information on this new feature, check out the help section: http://fusion360.autodesk.com/learning/learning.html?guid=GUID-B4BC813B-8697-4632-B57E-AC1E582E8C7A
Let us know your thoughts / questions / concerns, and thanks for contributing to the community!
Best,
Timera
