Exporting Drawing Issue
First of all I am a newbee in need of help.
I tried to export a simple 3 view drawing that I created from a 3D .stp file. I went to output / DWG. and saved it to a file, which I than tried to open in my CAM program. Upon opening it, all that was there was a layer for the drawing border. and a layer for the title block, without any part layer / image.
While on the subject, the output / export feature only had the DWG and PDF option listed. Is there a way to export in a DXF format ?
Phil
scott.price
Hi @Anonymous,
Thanks for reaching out - currently our views are a specific kind of .dwg object that unfortunately isn't well supported in other programs - we are looking at opportunities to improve this.
At the moment we don't support .dxf out from drawings, but if you right click on a sketch in the modelling environment you can save it as a .dxf
Hopefully this helps, and sorry for any inconvenience.
Best,
Scott
Thanks for getting back to me Scott.
So, I export from sketch, a single .dxf view, at a time, which is done through an email... Right?
Phil
scott.price
Hey Phil - It should be a direct file save to your machine.
Let me know if you encounter any issues. And if you get a chance, could you tell me a bit more about how you'd want to use a .dxf out from drawings -
-Scott
As I mentioned, I am new to Fusion 360 and plan to switch over to it as a my go to program for CAD and most importantly CAM. I plan to transision by first learning the CAD and than the CAM, but as a stop gap, I'll need to produce a .dxf or .dwg to feed my current CAM system.
I'll try exporting come Monday, and let you know if I have any issues.
Thanks for your help.
Phil
Dave.Sohlstrom
So it is now Aug 2 2016. Has there been any progress on being able to output standard DXF format files to be used with 3rd party 2D CAM programs.
Dave
scott.price
Hi @Dave.Sohlstrom
We currently rely on the DXF output of the sketch profile in the Model workspace - have you been able to use that workflow?
Best,
Scott
