06:28 PM
I'm confused about the project/include function.
I've drawn an initial sketch, and then create offset planes for each component. I create a sketch on the new plane and project the lines, curves, etc. from the original sketch as needed so I can work with them as a starting point on the new component.
It works but I suspect I'm doing something quite wrong here. First, I have to select each line individually. That alone suggests I'm off. Second, The dialog that comes up with project: always lists "Geometry:" as 0.
(new to cad, missing basic concepts)
Thank you!
