Projecting sketch lines onto a multi-faceted surface
lalkAGGCF
Message 1 of 13
lalkAGGCF
Hi all,
I'd like to be able to engrave distance markings at 1cm intervals on an organic surface. However, the organic surface is a BREP created from a complex t-spline, and therefore has many faces representing the surface. I tried to use the "project to surface" command, but it doesn't seem to work with more than one surface selected at a time.
Is there a better way to achieve a consistent depth line marking on this surface for engraving?
Thanks in advance for your help,
Lee
Replies (12)
Message 2 of 13
TheCADWhisperer
Can you Extrude as Surfaces and intersect?
Message 3 of 13
lalkAGGCF
Thanks for the suggestion. I tried to upload, but the .f3d file is 70mb and isn't accepted by the forum.
If I extrude as surfaces and intersect, is there any way to limit the depth of the intersection to a consistent depth, say, 0.020" from the surface? Otherwise it seems it would result in a variable depth engraving.
Thanks again!
Lee
Message 4 of 13
Hoping someone can help with this. I thought about creating a second copy of the model and shrinking it by a small amount, then using the projected sketch to cut only the original body. That would leave the smaller body as the base of the cut. But, this seems like a very processor intensive way of doing it - it's already quite a complex model, and I suspect if I duplicate it my computer will balk...
Message 5 of 13
TheCADWhisperer
@Anonymous
(See Message #2 above.)
If it is too large, can you zip and Attach or make a public link?
Or
Move the Timeline marker to Beginning.
Now export the file with the Timeline in this rolled back state.
Is the file now small enough to Attach here?
Message 6 of 13
lalkAGGCF
I uploaded a zipped version to google drive - hopefully this link works:
https://drive.google.com/file/d/1zAql3UuoT_FY4X5H910KLOr93-To4Rg3/view?usp=sharing
Message 7 of 13
lalkAGGCF
Just bumping this thread, as it fell off the first couple of pages of the forum.
Hoping someone can take a look for me, thanks!
Lee
Message 8 of 13
TheCADWhisperer
Do you need the large internal cavity? (Not referring to any features that extend to external "air".)
Message 9 of 13
lalkAGGCF
No, not at all. I actually didn't realize that was there - I thought I had filled it in
Lee
Message 10 of 13
TheCADWhisperer
Is this what you are after?
Message 11 of 13
lalkAGGCF
Yes! Please let me know how you managed it! Thanks very much
Message 12 of 13
TheCADWhisperer
Message 13 of 13
lalkAGGCF
Thank you!
For some reason, when I tried that before it gave me a different result - I ended up with only the areas that intersected remaining. I'll try it again with the options you show selected. Thanks again!
Lee
