Hexagon scoop
Hexagon scoop
symmetry.woodworks.ph
Hexagon scoop
Hi All,
I'm trying to figure how to create the model and what toolpath to do with this carving. Any help is appreciated, thanks!!!
shahriarsifat1802164
Something like that
Md. Shahriar Mohtasim
Dept. of Mechanical Engineering,
RUET
LinkedIn | Facebook | Youtube (CADs) | Twitter
Autodesk Product Users, BD
If you found this post helpful please hit the LIKE button and for a solution hit the ACCEPT SOLUTION.
Thank you.
RUET
Thank you.
I have attached the file.
Thank you.
RUET
Thank you.
davebYYPCU
Hex dome is easy enough,
cut it with 3d parallel, will depend on tool size as to what you finish up with.
Might help....
TrippyLighting
"interesting" solutions so far 😉
I propose that this is a simple pattern of spherical cuts:
This is amazing! Thank you!!!
