Projecting a Sketch onto a rectangular prism.
hmmiller
hmmiller
I know how to project a sketch onto a round surface. How do I project a sketch like this onto a rectangular shape? I am wanting to have a pattern continue around corners.
etfrench
Put the sketch in a component.  Circular pattern the component. Project to each face after aligning the sketch geometry.
ETFrench
g-andresen
Embossing is only possible on one surface element.
Therefore: emboss each surface separately
günther
jhackney1972
@g-andresen has the right solution and if you would radius the corners of your prism, just a slight bit, you can wrap the Emboss around multiple faces at one time.  Model attached.
John Hackney, Retired
hmmiller
It worked.  I rounded the corners to get one continuous pattern.
Thank you
