Projected profiles not closed
2 REPLIES 2
barry9UDQ6
289 Views, 2 Replies
Hi All
I have finished up my modeling on a project, and it is all in sheet metal. So now I need to nest and export DXFs.
This is my process:
  1. Create flat patterns of all components (all components modeled up from scratch in Fusion 360).
  2. Derive all flat patterns to a new part and 'arrange'.
  3. Create a new sketch and project all bodies.
  4. As the second pic below shows, not all of the profiles are closed, even though they were projected from a solid.
And another problem I am having is that the bend lines do not show up on the drawing:
And the last detail I need to include is part numbering in the form of text. Each solid has the correct part number in its properties, but I guess I need to number each part manually.
But the real problem is the profiles, some are open and some are closed. If I can't solve this I will need to pedit in Nanocad and I have many more parts to come!
2 REPLIES 2
davebYYPCU
in reply to: barry9UDQ6
Try DXFer - download from Github.
Step 1 is required, step 2 is optional,
Step 3 select the planar face of each part, where they are
DXFer will export all your parts to a single dxf file, where nesting will be required.  To date no errors detected.
I have previously reported sketch profile errors from projecting bodies, just as you have detected.
Might help...
barry9UDQ6
Thanks Dave
I have tried it out, but then I lose my nested sheet arrangement, and the polylines it creates are quite rough.
And I also lose my bend lines.
As much as I try to stay away from Rhino, I think a closecrv there is my only workable solution at the moment.
