Projected line problems
saschaschildbeck
saschaschildbeck
Hi there,
 I´m struggeling with the lines projection problem for quite a long time.
If I project a body conture in a Sketch and I edit the body, then the prjected lines become green.
projection.JPGIs there a way that projections update automaticly?
g-andresen
I just tested it and found that the described behavior only occurs when the sketch plane is redefined.
Can you create a screencast and/or upload the file?
regards
günther
