project turn purple
project turn purple
project turn purple
I was working on this project and started renaming one of the sketchs in the timeline and accidentally changed the color of the part to purple.  I don't know how I did it and would like to know how to remove the color and possibly to know what I did.  After the color changed I played around in appearances for a couple minutes and was not able to remove the purple color.  Also when I opened up appearances a warning shows up as well.
Any help or guidence would be great!
jeff_strater
hi @Anonymous,
Most likely what happened is you accidentally turned on the "component color cycling", by hitting the "n" hotkey while you were not in a command.
You can turn it off again by hitting "n" again, or using this menu item:
Jeff
Jeff Strater
Engineering Director
Thanks Jeff!  That was it and now I know  🙂
