Message 1 of 8
03:15 PM
- Mute
- Permalink
- Report
I am trying to project a sketch of a coil to the surface of a revolved feature. When I try it with a perfect cylandar the coil profile projects as expected but when the surface has a curved profile it only projects a small section of the curve.
The first picture shows the coil profile scetch and a the cylinder.
The second show the result of using project to surface to project the coil sketch to the cylinder's surface.
The third shows the result of projecting the same coil sketch profile to a revolve feature. You can see it only prjects a small section of the curve.
Any help would be greatly appreciated.
