- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
I have two instances where I have projected a sketch onto a plane, creating a new sketch. One was a projection of a sketched circle, the other a circular pattern of points.
When I change the diameter of the original curve, it does not get updated in the projected sketch! I don't find the "Project to sketch" menu very intuitive - usually takes several attempts before it works for me - but it clearly did work originally and I didn't do anything to break the link.
It seems to know it is linked because if I try to dimension it, it says it will be a driven dimension:
If I display all the sketches, there does not seem to be any sketch that could possibly be defining this dimension. What's going on?
Roger
