project to surface error with sphere
j2
j2
Hi Forum,
can anybody help me? I want to project some lines on a spherical surface. But the line that ends exactly on the mid of the sphere causes an error, see screenshot.
Mathematically it should work. What is wrong?
https://a360.co/38l3uoV
Regards, Jörg
pavmed
what usually causes errors in project to surface workflow is that by defaul projection mode set to "closest point" and usually this is not what needed.
I'd try to change it to "along vector" then select vector to project along and try again
j2
Hi Pavel,
thank you for your advice. I intended to use "closest point".
Regards, Jörg
