Project To Surface and Rolling Back
smbeever
smbeever
Hello there!
I'd classify myself as an intermediate Fusion user, but I seem to have a relatively simply problem, or perhaps I'm not understanding something correctly.
In short, after I project a sketch to a surface, I'd like to be able to edit the dimensions of the sketch used for the projection and have it update the projection without having to delete the projection and redo it manually.
Is this possible?  Currently, I try to change the dimensions, but the projection does not update with the new dimensions.
Is this possibly because the projection sketch is unique and is not linked to the source sketch?  If so, is there a workaround?
I feel I'm doing something wrong, but I've spent quite some time trying to figure this out.
Thanks!
smbeever
Apparently I'm blind and kept missing the "Projection Link" checkbox when performing the Project to Surface.  Checking that solved my problem.
Hopefully this helps someone else in the future!
