Project Silhouette
Project Silhouette
Project Silhouette
Has Project silhouette been removed from the sketch palette?  It no longer appears under the Project menu in the 2D sketch environment.
jeff_strater
the functionality is still there. It's just been merged into the Project geometry. If you select a body (either in the browser or using Select Other), you will get the silhouette.
Jeff Strater (Fusion development)
Jeff Strater
Engineering Director
jeff_strater
you can also use the selection filter in the command:
set it to Bodies, and you will get a Silhouette projection
Jeff
Jeff Strater
Thanks Jeff.  I will try these suggestions.
