Project Section View
Add the ability to project  the visible face or edges from a section analysis onto the active sketch.  A work around for this is to copy the body in question, paste it in the same position, extrude/cut the copy to the section plane location, project the faces/edges onto the sketch, select the projected curves and break connection to the copied body.  The copied body can then be deleted.  This works well but its a lot of steps that could be simplified by adding the ability to project the section view profile onto the active sketch.
schneik-adsk
You can use the Sketch -> Project -> Intersect Command.
Set the filter to body and select the bodies where you want the intersection edges with the active sketch.
Kevin Schneider
