project half a model
I am a beginner and trying to project half of a model and then enlarge it a bit with offset. The I want  to  rotate a cut in a part that fits over the model. It will be a clamp so I need some clearance between the two. Do I have to cut the model in half first or do I project the entire model and then halve it? I don't know how to do either procedure.
karyeka
The first reaction is to halve it first so that there is less geometry to project. Have you tried the Split command in Model workspace?
Can you attach your model? If you want you can send it to me only - anand.karyekarATautodesk.com
Anand
Fusion Engineering
Anand Karyekar
Forge Graphics
