I'm hoping to get some advice on how most efficiently to achieve a parametrically driven pattern over/around an edge. I realize this will require a lengthy answer... just hoping someone who's into parametric workflow evangelism would like to make an example in this vein.
Link to file: https://a360.co/2Xiqyly (not currently achieving desired malleability)
The example project is an enclosure for a laundry machine set. The actual dimensions of the cavity, given plumbing/electric/structural constraints are not known exactly. Additionally, the dimensions of the exposed materials for the enclosure (in this test case, wood ship-lap) are unknown. We need to move forward with facade design using estimated dimensions now.
The entire design dimensions will be altered later when we have the exact enclosure cavity and ship-lap dimensions. For this reason, the model should be driven by the cavity dimensions and the ship-lap profile.
Any advice on how to best achieve this? How to extend the ship-lap profile pattern over/around a corner (currently using individual profiles for each axis, along with rectangular pattern). And how to assemble the pattern bodies so that they will parametrically adjust to the cavity's dimensions.
Thanks!
